520 PTO Restoration....Thoughts about facings....
Tyler--MO
02-11-2004 19:44:49
Hello again all,
~I am really kicking up the dust here lately on the old 520. I cleaned, primed, and painted my rear rims. I'm getting the BF Goodrich 13.6-38" tires and BF Goodrich 5.50-16" tires and tubes this weekend from a fellow in Iowa...(MUCH LESS COST THAN MILLER TIRE)..I will share his info with anyone interested in saving like $55 bucks per tire. ~I found lots of NOS parts from people that resonded to my wanted ads (for my pto clutch) and I also am buying a really good looking flywheel cover from a 50 (same part # I did my homework and checked) for only $50:)
~My thought this evening are about pto clutch facings. I found 4 originals (the old part number) and will have to finish the remainder with the sub part number. I am leery about mixing them up but like my dad said, there is a metal facing between all of them so it shouldn't be a big deal?? I hope it won't be a problem at least. I'm going to replace all of the bearings, thrust washer, and seals also.
Someone emailed me and asked "What are you going to do with this tradctor that it will look immaculate plus be in super mechanical shape?" I told him that I plan on showing and using it on the farm (light chores, not spreading manure or really dirty work) maybe raking or tetting hay. I hope to find a 2 blade disc plow for it to use/show....those are few and far between...but I had better get the tractor done before I get carried away....the money isn't plentiful right now so I better just wait (how about asking Santa Claus for one)
~Returning to the PTO topic...I'm thinking about running Hy-Gard in the powershaft after it's back together with new parts. I would think that it should be better for it than 30wt?? Any thoughts?
Well...I must go now and concentrate on homework, what to get the girl friend for Valentine's Day, and maybe even SLEEP....
Thanks for all the input over the past several months...and feel free to post here or reply by email if you have questions or whatever....I like to b/s anyway. *imagine that one....
Tyler-MO
will
02-12-2004 14:33:54
 Re: 520 PTO Restoration....Thoughts about facings. in reply to Tyler--MO, 02-11-2004 19:44:49
Well spit it out. Who sells tires cheap? Are they 45 degree tread? How much was that 13.6 and tube? How much were the 6.00s and tubes?
Clooney
02-12-2004 03:43:06
Tyler, it won�t hurt anything to use different types of lined disks [I mix & match those all the time].. If it were an automatic transmission you could end up with a harsh shift or harsh engagement but that isn�t a factor on a PTO clutch..
~On the PTO oil??.. I don�t see why Hy-Gard wouldn�t work but why not use the called for oil as that has worked for years with a good track record.. Personally I like non detergent motor oil as it has less super slippery additives in it..
[email protected]
Brandon
02-12-2004 09:36:19
 Re: Re: 520 PTO Restoration....Thoughts about faci in reply to Clooney , 02-12-2004 03:43:06
What do you think about using 10W-30?
Brandon
My Industrial John Deere website
John Deere Diesels
The LaGrange Engine Club
