1949 John Deere A starting problem.
timbo2
12-24-2004 05:25:48
Just got the tractor and I'm having a rough time starting it. On the occasions I do get it going it runs great. Any hints will be appreciated.
phil2
12-24-2004 10:48:56
 Re: 1949 John Deere A starting problem. in reply to timbo2, 12-24-2004 05:25:48
There is a coil spring on the choke lever at the carb. It is possible for the choke to stick in the "open" position. It will stay open even when you pull the choke control.
BushogPapa
12-24-2004 10:09:16
Everyone who buys one should get specific instructions on how to start that particular JD...
I don't think there are any that start the same way, and with the same choke and throttle settings..!!! Some don't need any choking, and the throttle at Idle, others need to be choked 2 to 3 turns, others would be flooded with that much choking..!! I like to shut the fuel OFF after (or before) I stop the engine, and then I KNOW there is no flooding when I go to start them... Next time you have trouble starting, check the plugs and see if they are wet...you may have it flooded...!! Ideally they should start on the first to 3rd turn.. Ron..
donwisc
12-24-2004 07:57:27
Start searching the archives, Between Clooney and John T and others this has been covered many times. Dont worry about which model A B or G, the problems and solutiuons are basically the same for all
