620 all fuel carb?
JD hauler
12-23-2004 20:43:06
can someone help identify a 620 all fuel carb, has hex plugs that cover the main nozzles and only two small holes near the throttle plate, anyone? we need a gas carb, any traders for a good carb, this one has been extensively cleaned and all , just wont idle on the tractor, without half choke, some guys have told us an all fuel carb will never idle right on a gasser, also the carb has a sort of square ID tag on top? thanks in advance.
JD hauler
12-24-2004 10:04:43
 Re: 620 all fuel carb? in reply to JD hauler, 12-23-2004 20:43:06
why does it only have two small holes at the throttle plate instead of 3 like others I have seen, tried the carb on two 620's and got the same results and the one is a known good runner, so it cant be the intake as they are both new, had all passage ways cleaned except the steel balls, but looks like you can get to all the passages with the welch plugs all out, where are these passages at?
Smitty620
12-24-2004 15:41:51
 Re: 620 all fuel carb? in reply to JD hauler, 12-24-2004 10:04:43
Mr. JD hauler
The carb passages on the Deere duplex are really hard to clean. There are some passages that run from the bottom of the carb. that feed up into the idle passages. You have to remove the lower caps, then remove the main jets, then clean way up into the idle passages. I used a stiff wire, some spray carb cleaner and compressed air for cleaning , but even then it is difficult. It helps to soak the carb. in some strong carb cleaner for about a week first. The way most carb shops do it is to remove the balls from the idle passages, however this is real difficult. Per Clooneys e-mailed directions I was able to use a soft wire and clean those passages without doing this. It is a must that you pull the throttle plates out to get at those passages. Just spraying some carb cleaner will not do the trick as it will not loosen the crud or more likely rust. I had my carb off a few times before talking with Mr. Clooney then after reading his e-mail a few times to understand what he was trying to tell me I shined a strong light up in the jet area and could see the passage on top where the main jets are. I used a very small drill bit to clean the passages and used soft wire on the orifice holes. Once reassembled and bolted on it ran perfectly.
I don�t know what to tell you on you only having 2 orifice holes. Mine had 3. I also thought I only had 2 on the left side but Mr. Clooney convinced me to look again and to look closer so with that in mind I found the 3rd hole that was blocked with rust and looked just like the carb. bore. You must have one hole on each side that is behind the closed throttle plates so if there is none behind the closed throttle plate those are probably plugged solid.
I wish I had kept Mr. Clooneys e-mail but have since switched IP companies so lost all my old e-mails. The above is what I remember from his e-mails and what I remember doing. I think there was something else but it was a while ago I can�t remember all I did. I got so frustrated I was going to send my carb. to a professional but the cost was very high and the turn around time was long. Actually the job didn�t seem that difficult once I received some good guidance from a very professional Mr. Clooney. I would have never figured it out without his help.
buickanddeere
12-24-2004 14:13:52
Sometimes the best way out is to send the carb to the fine folks at Robert's Carburetor. The price is reasonable, the workmanship top rate, the proper tools and replacement parts used. And the carb isn't shipped until proven 100% on a dyno test run.
Smitty620
12-24-2004 07:14:08
Mr. JD Hauler
As stated by Duane and buickanddeere there really isn't much difference between the all fuel and gasoline Deere duplex carb. What that means is either will work on either tractor as long as gasoline is the fuel used. Both the all fuel and gasoline carb will yield a good clean idle on a healthy gasoline 620 tractor.
Your lack of a good idle isn�t from the wrong carb but from a plugged idle passage or passages inside the carb. or a manifold leak. The reason I know is I had the same problem a year or so ago. You might want to search the archives for a post by JDClooney on this subject. He posted a way to use needle nose pliers to work a soft wire through those internal passages without removing those passage end balls.
I dealt with Mr. Clooney by e-mail and he helped me clear up a similar problem on my tractor. While my problem was a little complex due to a double problem he identified the problem right off. It was a small internal crack in the intake manifold allowing exhaust gas to enter the intake and also a plugged left idle circuit. So check your manifold for internal cracks and look for a leak at your manifold heat control valve due to improper setting of the valve.
Duane Larson
12-23-2004 21:56:38
JD hauler,
Besides agreeing with buickanddeeres comments, I would note the square tag, if stamped DLTX109u, indicates the carb is a "generic" replacement carb used on all duplex applications. It should work ok, but is probably not "tuned" for the particular application.
buickanddeere
12-23-2004 21:33:28
Only differnce between a gasser and all fuel carb is a couple of jets and a pair of fuel pickup tubes. Distilate is more viscous (thicker) than gasoline and needs larger jetting. If fact just by changing jetting that same carb is used on the 60/620/630/70/720/730 gassers and all fuel models. A look on the Roberts Carburator site will show the different jet/orfice part numbers. The failure is due to idle air and fuel passages that were missed during the extensive cleaning. Robert's carburator has the drill bits to clean the passages and a diagram to show some passages that exist but are well hidden. Sometimes the steel ball plugs have to be removed in order to clean out 46+ years of rust,dirt and gummy fuel.
