Fan Shaft rattle!?!
SSlyter
12-23-2004 19:55:52
Hey guys, maybe you can help me out. On my 46 JD A there is a sleeve over the shaft that goes to the fan. Well, the sleeve is loose and rattling....how do I thighten this sleeve up or is there a gasket that is missing??
Thanks!
Lee B
12-25-2004 03:16:37
 Re: Fan Shaft rattle!?! in reply to SSlyter, 12-23-2004 19:55:52
If the sleeve you mention is full length and not some add on do-hicky, it should be spring loaded by the fan"s slip clutch springs which is a substantial amount. Certainly enough to keep it from rattling. The inner shaft would then have to be stuck to the bearing (and not sliding) just behind the fan itself? Rattle might also mean that the driven gear on that shaft can slide in and out which will wear on the governor shaft gear as well. $384 for those gears new so you might want to do some preventive wrench twisting before you have to buy it all new. Only way I know how is to remove governor housing and fan shaft and tear into it. Steering wheel and rod, gas tank, upper water pipe, governor housing and exhaust pipe all have to be removed to get the fan shaft out.
You might loosen the fan bearing mounting bolts at the frame attachment points (2 bolts) to see if they are pulling the shaft forward via a bent too much/not enough mounting bracket first. I"d hate to send you to that other place if this is all that"s wrong.
Backlash for above gear set is closer to 1/10 of an inch fan movement at fan diameter although you will see 1/2 to 1 inch quoted. The larger dimensions include all slack in all gears and NOT the fan shaft/governor set alone. At impulse timing mark on left side compression, one can feel the 1/10 inch with a delicate touch, you can then also push against spring loading to feel the other slack come out as well. It"s the 1/10 inch measurment that is important, if it"s twice that then you are running with an equivalent of .010 or more backlash in the gear set and that"s too much. She"ll start eating those gears up directly if there is too much clearance in there.
SSlyter
12-27-2004 08:25:02
 Re: Fan Shaft rattle!?! in reply to Lee B, 12-25-2004 03:16:37
The part that is rattling is a sleeve that surrounds the fan shaft. I can grab it and the rattling stops. So, who knows?!?! I will find out the problem once I tear the tractor down to begin the restoration.....
BushogPapa
12-24-2004 10:12:24
Has it been greased lately.??
If it is greased, it may not make any noise....
Ron..
Walt in Jaxn Tn.
12-23-2004 20:22:12
Are you sure that's not a spacer? Do you have a parts book for the "A", If not, someone could post a view of the parts of the fan shaft. I've had a "B" shaft apart and seems that there is a spring that holds tension against the bearings on both ends. Can you move your fan shaft side to side or up and down from the fan end with your hand? --Walt--
