Delco Remy Magnetos
Raymond Turner
12-23-2004 18:39:11
I ran across 3 Delco Remy mags that are painted JD green. 1131558 7D7 is stamped on a metal plate on one of them. The cap has 3 plugs. They have a lug base on them that looks like JD used on Wico mags. Could these be from JD and if so what models might they fit.
Duane Larson
12-23-2004 19:44:50
 Re: Delco Remy Magnetos in reply to Raymond Turner, 12-23-2004 18:39:11
Raymond,
These are distributors, not magnetos as DR never made a magneto that I am aware of. If the number is 1111558, it is a DR distributor that will fit A, B, G, D, 50-70. It requires an external coil (like a car) and a battery to produce a spark (a magneto uses mechanical energy to generate a spark so does not need a battery). The 7D7 implies it was built on April 7, 1947 (or perhaps 1957).
I'm not sure what a 1131558 would fit.
