3020 battery charging
J bouchard
12-23-2004 12:57:32
I have a friend with a 3020 that doesn't recharge one of the batteries all the time. He asked me about this problem but I am a 2-cylinder collector, so I know little about this type of problem . Where does one start to look for the cause of this ?
buickanddeere
12-23-2004 18:02:31
 Re: 3020 battery charging in reply to J bouchard, 12-23-2004 12:57:32
Batteries of different age, manufacture or size will never stay evenly charged. Often as the starter brushes wear, the carbon dust inside begins to slow discharge one battery. On occasion the generator or regulator will do this too. Place a small 12V light bulb in the ground wire circuit where it runs to chassis 1/2 way between the batteries. Shouldn't glow when tractor is shut off.When running there should be less than an amp through that wire. System charging voltage should be 28.4V measured at the batteries in cold weather.27.6V in summer. Don't get rid of the 24V system. They winter start very well if understood and properly maintained.
Gerald J.
12-23-2004 17:02:35
With two batteries, its a diesel. They are in series, but the auxiliary loads like lights are split between them. First chance is that the charging system isn't charging well at all, the second chance is that there have been accessories like lights added without splitting them evenly between the +12 and the -12 volt systems. That diverts charge from that battery.
Gerald J.
