2750 oil leak
mk4020
12-23-2004 09:12:37
There is a thin drain/bypass? hose coming off of the rear hyd outlet hanging down behind the left rear axle housing. I"m leaking trans oil out of it at a rate of a gal/3hrs. Doesn"t matter if hyds are in use or not. What do I need to fix here? MK
david val
12-24-2004 04:26:04
 Re: 2750 oil leak in reply to mk4020, 12-23-2004 09:12:37
look for a fitting for the hose on the left side of the rockshaft housing.
david
R. John Johnson
12-23-2004 10:20:18
I think the purpose of the hose is to drain off any oil that leaks when connecting or disconnecting your quick couplers. I am no expert, but If you have a steady leak there, it would seem logical that the leak is in the control valve and possibly a secondary leak in the seals of the coupler body. Hopefully someone else will know what you need to do to fix it. Is the tractor an open station or does it have a cab?
John
mk4020
12-24-2004 17:10:17
 Re: 2750 oil leak in reply to R. John Johnson, 12-23-2004 10:20:18
It is an open station with a 245 ldr pluged into the two rear hyd outlets.
