3010 Zenith carb
Gordon
12-23-2004 08:07:54
Where can I get a new zenith carb for a 3010. Or a rebuilt, or have mine totally rebuilt like new?
Gordon in SD
Gerald J.
12-23-2004 11:36:53
 Re: 3010 Zenith carb in reply to Gordon, 12-23-2004 08:07:54
Shoup, value built (not spelled that way), this site, probably TSC, and JD.
Gerald J.
Gerald J.
12-24-2004 04:12:57
 Re: 3010 Zenith carb in reply to Hoosier JD, 12-23-2004 21:05:13
I know dumping the M-S for a Zenith is popular. Looking at the 4010/early 4020 shop manual that I have, I see that adjusting the M-S is not simple and I suspect that the large vacuum diaphragm that runs the accelerator pump has ripped by now and lets lots of fuel in through a vacuum line to make the fuel consumption high. Its not a cheap part to replace and so I suspect its not replaced when rebuilding the M-S carburetor. Its not a part of the common rebuilding kit.
My 4020 came with a Zenith and it works pretty good. I cut the fuel consumption a great deal by several steps.
1. New AC plugs.
2. New copper plug wires.
3. Proper ignition timing.
4. Choke wire sheath hooked up so it really opens the choke. Halfway wasn't good enough.
5. New float needle and seat. The JD shop expert on gas engines wouldn't talk to me about tuning until I did that. And the old one was worn badly.
6. The top of Donaldson precleaner pushed up instead of down from years of overtightening.
7. Loose junk removed from the intake manifold.
8. Clean air cleaner element and pipes.
Before I did all these things, it smoked like an IH diesel with a big cloud when goosed after idling a few minutes. Now I have to choke it even for warm starts. I think its lean enough.
Gerald J.
