JD 440ID Performance
Mike W
12-22-2004 10:10:46
I just picked up a 440ID with a rebuilt engine. It has a Loader and backhoe. It doesn't seem to take much to stop the drive wheels from turning when trying to use the loader to scoop a load of gravel. There is also a 1 sec pause between when the clutch is released to when the wheels start turning...Is this normal or is the clutch slipping?
Mike M
12-22-2004 12:19:22
 Re: JD 440ID Performance in reply to Mike W, 12-22-2004 10:10:46
You should be able to SPIN the wheels when digging or if you get enough traction you should be able to STALL the engine down. It sounds like you can't do either so your clutch is slipping or if you have a directional reverser it may be slipping. Check adjustments on both first before tearing into it.
mikew
12-22-2004 12:27:22
 Re: JD 440ID Performance in reply to Mike M, 12-22-2004 12:19:22
Thanks, I thought that should be the case. I am on the hunt for a maintenance manual right now. It does have a directional reverser as well.
Suggestions to locate a manual?
buickanddeere
12-22-2004 14:26:07
 Re: JD 440ID Performance in reply to mikew, 12-22-2004 12:27:22
1-800-522-7448 cheap & direct from Mother Deere.
