Type of Oil in Power Trol on JD A
BB
02-11-2004 18:20:29
I know that the Power Trol System on My A calls for 30 weight oil, but can I use detergent oil like you run in a car or do I need to put non-detergent in the system. Sorry for all the ? but I am new at the JD tractors. I have a shop manual but could not find the answer to this in there.
BB
02-12-2004 18:02:15
 Re: Type of Oil in Power Trol on JD A in reply to BB, 02-11-2004 18:20:29
Thanks for the input.
Tyler--MO
02-11-2004 19:13:29
Depending on use....I would use ND 30wt...however I haven't had any problems with detergent oils in that style hyd system (low pressure). If it's not been recently redone I'd stick with ND....as the detergent might losen a bunch of crud that could cause problems. Tyler-MO
Justin J
02-11-2004 22:46:05
 Re: Re: Type of Oil in Power Trol on JD A in reply to Tyler--MO, 02-11-2004 19:13:29
We run 30 weight hydraulic oil in ours with no problem. i think that pretty much anything around 30 weight oil regardless of type will work for ya.
