SRJ, First remove the cap and rotor button, and clamp the magneto in a vise using the flat spot on the magnetic rotor shaft where the rotor button was to keep the shaft from turning in the vise.The bearing is accessed by removing the impulse unit, consisting of the drive cup nut, drive cup and spring, some spacers, the impulse driven flange (the piece with the impulse trip arms attached, it is a snug fit on the shaft and will likely need to be pried off with a pair of screwdrivers), and a round thin disc over a rubber seal. When those are off, remove the four screws holding the impulse stop plate and remove the plate. Be very careful to keep the parts in order as they come off the magnetic rotor shaft!! Then remove the magneto from the vise, and bump the end of the shaft (from where you removed the rotor button) with a brass hammer. The (friction fit) bearing holder (and magnetic rotor) should move out of the impulse end of the magneto. Be careful how hard you bump the rotor as the (aluminum) bearing holder has a spring clip which holds the bearing in the holder, and the material around the clip is subject to breaking if the rotor is pounded too hard. If you don't have access to a magnet charger, don't move the magnetic rotor more than about 1/4", which should be enough to free the bearing holder from the magneto case. Then slide the bearing holder off the shaft (leaving the magnetic rotor in the magneto) and remove the spring clip holding the bearing. Then press the bearing out of the holder (again, carefully) and press in a new one. Then reassemble the impulse drive unit in the order you took it apart, being careful when the magnetic rotor and bearing holder are pushed back in to make sure the movable point slips up on the magnetic rotor cam properly, and replace the rotor button and cap.
