Governor Noise on a Late B
Rooster in Tenn
12-21-2004 15:59:19
I started my B the yesterday an a noise starting coming from the governor case. It was making a squealing sound from the case. It sound like it coming from the magneto side of the housing. Thank"s for help
BushogPapa
12-22-2004 07:24:09
 Re: Governor Noise on a Late B... WAIT..!!! in reply to Rooster in Tenn, 12-21-2004 15:59:19
BEFORE you do anything to the governor..Grease the Front Fanshaft bearing...!!! If it starts to squeal, it sounds like it is comming from the governor...!! Put a grease fitting in it in place of the square plug--on top of the front fan bearing houseing, and grease it good...!! Many forget to service that bearing...!!!
Ron...
Duane Larson
12-21-2004 20:52:58
 Re: Governor Noise on a Late B in reply to Rooster in Tenn, 12-21-2004 15:59:19
Rooster in Tenn,
If you have a Wico XH magneto on your B, a failing ball bearing in the magneto can make a squealing sound. Most governor bearing failures I have run into make more of a roaring sound.
