Changing hydraulic oil 50
rej
12-21-2004 14:04:51
It will be several weeks before i receive the manual to my 50. The hydraulic and transmission oil is milky looking and needs changing. I noticed there are several drain plugs on the bottom , will all of these have to come out? Does the hyd. and trans. use the same oil and reservoir? What type oil and how much goes back in and also were to pour it in? This is my first JD. thanks
gathje
12-21-2004 20:12:07
 Re: Changing hydraulic oil 50 in reply to rej, 12-21-2004 14:04:51
Its the large plug on the rock shaft housing or the housing bolted onto the axel housing.there is a little plug near by to drain the pto oil .Realy it is the big plug nearest the rear of tractor almost in the center of tractor .Looks like it drains transmission but does`nt.JOHN DEERE DEALER SOLD ME HIGH GARD OIL -John deere product -but was`nt that bad a price.transmission gets regular gear lube.Im told GL1 gear oil big discussion about GL1 AND GL5 ?I think about 1 and half gallon hygard is used or till it comes out little opening looks like radiator drain plug.fillat plug up high in middle behind seat.
