COLD STARTING DEERES
TIMAR
12-21-2004 08:31:15
Need some professional opinions on this. I have a 91 model 4455. This thing will start at 15 degrees if I want it too. Is this hard on the engine? I have only done it once, when I needed it right now. I let it warm up for 15 minutes before putting it in gear. The engine was knocking for about the 1st 30 seconds. I did not use any ether by the way.
JD720D
12-21-2004 20:00:28
 Re: COLD STARTING DEERES in reply to TIMAR, 12-21-2004 08:31:15
You might find these cold weather starting techniques used by bush pilots flying small aircraft in climates such as northern Minnesota and Canada of some benefit.
- pre-heat the engine with a source of heat. Popular devices include a 20# LP bottle with a Mr. Sun heater and a short section of ductwork running to the engine cowl. A blanket or other cover over the engine accellerates the heating. I imagine a salemander heater could be used in a pinch - may need to provide some length of ducting to preclude flames from reaching your engine.
After shutting off the engine for the day, pilots will often put a 60 watt lightbulb on a trouble light under the cowl (again, with a blanket or other wrap around the engine). This is often enough to keep the chill off and maintain some level of heat in the engine.
I"ve also heard that Alaskan pilots would sometimes pour a small quantity of gasoline into the crankcase before starting. The gasoline would reduce the viscosity of the oil and would burn off (or evaporate?) naturally soon after starting.
Pilots also sometimes remove the spark plugs from their engines and bake "em in an oven just before startup. Quickly install the plugs when ready to start. The heated spark plugs will resist fouling by condensing moisture on the electrodes.
As a side note, I remember one cold MN winter many years ago when I had to use a hot air popcorn popper on the oil pan of my old Chevy before it would start.
All in all, it is probably easier to install a block heater.
As to heating the battery, remember that excessive heat is harmful for battery longevity. If your engine is sufficiently warm (and is reasonably healthy), it will turn over fast enough that you don"t need a battery heater.
TIMAR
12-21-2004 16:06:01
Thanks for the replies. It does have a block heater, and I always use it. It was just that morning, we needed that tractor for an emergency.
By the way, I have never used a heater on batteries. How do they work? I was told to turn on the lights and that will warm them.
buickanddeere
12-21-2004 17:56:55
 Re: COLD STARTING DEERES in reply to TIMAR, 12-21-2004 16:06:01
Battery warmers are either a heated blanket wrapped around the batteries. Or my favorite is the "hot pad" type the battery sits on top of. It stays out of the way better and allows a bigger battery to fit in the battery box. The warmer and a intelligent trickle charger on a well maintained tractor filled with synthetic oil will start a suprising low temps on short notice. Doesn't use very much standby power either. I've had people ask why I plug in equipment in cold weather even though it would start without pre-heating. They didn't seam to notice the quick easy starts, the rapid supply of heat to the windshield defroster and the lack of fuel wastage from extended idle warmup time. Along with poor fuel effiency from a cold engine. A clear windshield instead of a peep hole to look through as well. Many vehicles get stolen while left warming up outside too.
G/MAN
12-21-2004 13:31:51
You've got a good solid engine there if it will start at that temp without ether or being plugged in. If you want to keep it that way, I'd strongly suggest using a block heater at the bare minimum, and use one installed in the factory location on the LH side of the engine block, as the element is located very close to two of the cylinder liners. And it will definitely need to be plugged in for an hour at the minimum if you want it to do much good - two to three hours would be better. There's about 1500 lbs of engine you're trying to heat up there, and it will take a while to get heat to all the liners and the whole cooling jacket. And yes, cold starts with thick oil are absolutely the worst thing for an engine encountered during normal operation.
buickanddeere
12-21-2004 12:39:19
The knocking was the sound of an engine running without lubrication. Mineral oil at those temps is like cold corn syrup and slow to get into the oil pump and through the filter/oil passages. Mother Deere sells a synthetic oil as well as Amsoil and Mobile 1. Other brands of synthetic are made to lower standards. As previously stated by others. Can't beat battery heat, battery trickle charger, oil pan heat and coolant heat for winter starts. A warm battery also charges much faster.
Dean Barker
12-21-2004 10:41:32
I like to plug in the block heater for at least an hour if it is in the 30's even. I guess I won't have to worry about my 4320; It won't start with out heat below 50 degrees F. I don't care to use ether.
BushogPapa
12-21-2004 09:54:42
Any colder than 15 degrees, and you should have heaters on the batteries, too...
BushogPapa
12-21-2004 09:54:46
ChuckW
12-21-2004 08:35:06
I'm sure all the cold starting has it's wear on any engine. A friend of mine worked at local mines for years, he said they took a pan of hot charcoal and let set under the machines for a while and starting was a breeze. I'm sure any kind of heat or especially a block heater would be in order for your tractor. Would save you some grief in the long run.
msb
12-21-2004 08:49:01
 Re: COLD STARTING DEERES in reply to ChuckW, 12-21-2004 08:35:06
Supposedly 95% of engine wear occurs duing warm up.If your tractor doesn't have a block heater,one is available.Hook it to a timer and set the timer to come on about 20 minutes before you plan to use the tractor.The block heater and timer will more than pay for itself in short order.Your heater will also be warm right away.
