adding a hydraulic port and valve to a 1530d
junker
12-20-2004 15:43:49
I have a 1530D with a 3point lift system but no hydraulic valve and ports for other implements. Can this be added with aftermarket parts? Where do you tie into with the supply and return lines?
What fittings are necessary. I primarily will use it on a smaller 9 ft disk. thanks.
Allan/NCA
12-21-2004 20:19:21
 Re: adding a hydraulic port and valve to a 1530d in reply to junker, 12-20-2004 15:43:49
A few years ago we added hydraulics to a 301A JD and the dealer sold us after market valves and hoses and told us which ports to use. The 301 is the same as a 1020, my 300 and my 2640 use the same ports for hydraulics. So if you can't find a used set up in any tractor yards, you can just look at a tractor with power to back and copy it. As the other say put at least a double valve. Good luck Allan
Walter Squires
12-21-2004 09:17:50
Use the Original JD set up new or used, Very easy to install, do yourself a favor and go ahead and put dual remotes on it while your at it, you can never have enough remotet outlets on a tractor. the same ones fit a 1020, 2020, 2040 etc.
msb
12-20-2004 20:47:22
I think your best bet would be to find a used and complete unit off a junked tractor.Check at your nearest tractor salvage yard.They about all are connected to a locator system that can find one if any are available.That would be the easiest and simplest way to do it.Good luck,bob
