#5 Mower
jdhbag
12-20-2004 14:28:41
Can anyone tell me how the crankshaft on a JD #5 mower is removed. Should it be driven or pressed toward the front crank wheel or should it be pressed toward the rear crankshaft sproket. I need to replace the oil seal.
Jake
12-20-2004 22:11:21
 Re: #5 Mower in reply to jdhbag, 12-20-2004 14:28:41
The crank wheel/fly wheel is held on the shaft by a tapered key driven in the keyway. That is the only thing that holds it on. Some have had good luck to drill and tap the key and use a slide hammer arrangement to pull the key out. If it's not too tight a gear puller may pull the flywheel off, but look to be sure the key is coming off with the flywheel and not staying with the shaft, if it stays with the shaft as you pull the flywheel it will get tighter.
Once the flywheel is off, you can unbolt the plate with the seal in it. Watch for and keep track of any shims, they are used to adjust the bearing preload.
FYI, the sprocket on the other end of the shaft is threaded onto the shaft.
I Bleed Green
12-20-2004 14:57:12
Pull the flywheel off with a puller. 3 jaw is best.
