Bush Hog selection for JD Model M ? ??
Niner
12-20-2004 11:44:20
I need to get a bush hog for use with my Model M tractor. I have a three point adapter, made by (I think) Worksaver.
I have been cautioned by at least one fellow to be carefull when selecting a bush hog, as the mounting pin locations on some of them will cause the drawbar to be in the way of the PTO shaft.
Do any of y'all know anything about this?
What brand, and size of bush hog do you run on your Model M?
Should I just forget looking at three point units and look at pull behind ones??
chooch
12-20-2004 13:33:39
 Re: Bush Hog selection for JD Model M ? ?? in reply to Niner, 12-20-2004 11:44:20
Niner,
I have about 4 acres I mow several times a year with a JD 'M' and 5 foot bush hog made by King Kutter (bought at local farm store). I try not to let the grass get much over 18" tall between mowings. I did have to bore two new holes and install new 3 pt. hitch pins for it to work on my tractor without hitting the drawbar. My tractor still has the original drawbar configuration because I have several pieces of M equipment that I still use. I made an adapter (similar to the mounting plate on the M equipment) to allow me to use the 3 pt. hitch on the bush hog. I do not use the center link and as a result I am not able to completely raise the mower off the ground. I am able to adjust the mowing height by raising or lowering the hydraulics for the drawbar.
Chooch
Mike M
12-20-2004 13:17:19
When I bought my model M it had an aftermarket 3pt. and a 4 foot bush hog and yes it it was an original made by bush hog. Anyhow I sold the 3pt and the bush hog as the top link would jamb into the tool box under the seat and you couldn't lift the lift up much or the pto shaft would hit the cross bar. I made a 3pt. which is more like a fast hitch and have used a 5 foot landpride finish mower on it some and a 5 1/2 foot ford flail mower.I think if your tractor is running good and you are not in stuff as high as the hood it may handle a 5 foot brush cutter but a 4 foot would be better until you get everything cleaned up.
Wayne in Tn.
12-20-2004 14:44:20
 Re: Bush Hog selection for JD Model M ? ?? in reply to Mike M, 12-20-2004 13:17:19
Good advice above, a 4 or 5 footer will work ok with the M. I will add one more thing, get an override clutch adapter for your PTO shaft. This will make it work almost like "live" and will not allow the bushog to "push" the tractor into a tree, fence or pond.
