JD 420 Tricycle parts needed
TomL
12-20-2004 09:18:17
I am looking for trunnion bolts used for connecting three point arms to drawbar assembly. JD part # M1925. Need one possibly two. Does anyone know where to get these other than from JD parts? Any help locating these would be appreciated.
Tom
lgc
12-20-2004 19:16:44
 Re: JD 420 Tricycle parts needed in reply to TomL, 12-20-2004 09:18:17
I was looking for one of those about 3 years ago. Local JD found one at a distance for about $50. I decided the one i had wasn't so bad after all. At least they are appreciating in value faster than my 40t.
Henry J
12-20-2004 14:44:01
Tom
I had the same wollered out deal on a Wide. I converted it over to the type trunions that you secure with a snap retainer like when you put implements on the other end of the arms. There is always a bunch of those generic replacement parts hanging on the racks, even at JD here.
I did have to put a spacer (not that big) between the arm ball and the pin to snug things up. I used the ole 2 foot breaker bar to put them on and they have been happy for over two years.
I think you could figure out something along that line that would lash up, for around $10 each - but then it would not get first place at the EXPO - sigh
happy holidays
Wayne in Tn.
12-20-2004 09:34:10
Tom, that is a common part to be worn out on those tractors. The Deere website shows M1925T to still be available for $95 each. It will be doubtful if you can find used ones in good condition. You might try John Shepard at 715-265-4988
toml
12-20-2004 09:41:41
 Re: JD 420 Tricycle parts needed in reply to Wayne in Tn., 12-20-2004 09:34:10
Thanks Wayne for the reply. Used would be better that what is on it now. Someone replaced left side with a straight bolt with a bunch of washers and it just flops around.
Tom
