49 B upper water pipe
Billbob
12-19-2004 16:42:38
Just got a B model that had been setting for many years cranked up. When I went to fill it with water I discovered that the upper water pipe was rotted through. Not sure if these are available and at what cost from a dealer. Has anyone attempted to repair one?
ChuckW
12-19-2004 18:04:30
 Re: 49 B upper water pipe in reply to Billbob, 12-19-2004 16:42:38
there's a ton of stuff on ebay for B's and one cat is parting one out. Bet you could get that item from him.
Billbob
12-19-2004 17:56:47
Thanks to all for the information. I'll try to braze a new pipe in. Not very confident of finding a good used pipe. I have a parts tractor and when checked found that one rotted also.
Mike M
12-20-2004 05:27:20
 Re: 49 B upper water pipe in reply to Billbob, 12-19-2004 17:56:47
Try that Sharps place or K & K someone may make a correct looking and sized one by now.Pretty hard to find a 50 year water pipe in good shape. I can live with a new pipe that should last another 50years even if it doesn't suite the correct police.
ChuckW
12-19-2004 17:51:56
the bear bites you in the b.....when you find you spent $10 at the muffler shop, then used $20 bucks worth of oxygen, accetylene to brase the pipe, then you find you don't have the correct looking bend in the pipe...then it looks like cra.... when you could have gone to salvage yard and found a good original for a few bucks....if you are going to weld you might just nickle weld the pipe in place, however it again will not appear anything like original if not careful and grind or dress down neck....
Mike M
12-19-2004 17:32:20
I have done some of these and they go pretty good. Guess I just have a better bear trap ? First check with K & K antique tractors to see if they are reproducing that pipe yet. It is 2 7/8" I used 3" exhaust pipe had to bore out upper casting in a mill to accept it had a muffler shop put the bends in it to match old one. I braze the new one back in I think I soldered one once. To remove the old piece just cut off the old pipe 1" or so ahead of the casting leaving enough to get hold of.Once pipe is out of the way take a cutting torch and start at the edge of the 1" left hanging out and cut straight back into the inside of the casting cutting all the way through the pipe,don't worry the old pipe should burn/melt out before the casting gets hurt just go at a good pace and cut it before the casting gets too hot.Once the old pipe is split clamp a vise grips on the part sticking out next to where you just cut now take the cutting torch and heat the pipe on the inside,don't hit the oxygen ! Concentrate the heat onlt in a small area inside at a time and when the pipe is red hot roll it up in the vise grips.You may need to cut more off and start over as too much gets jambed up in your vise grips. Hope this makes sense as it is harder to explain the to do it.
forgot a step
12-19-2004 17:36:22
 Re: 49 B upper water pipe in reply to Mike M, 12-19-2004 17:32:20
Once everything is all cleaned up I trial fit it on the tractor then remove it (try not to let it move) then braze it.
jdhbag
12-19-2004 17:27:30
Sharp's in Missouri has new replacements pipes with the correct bend that can be brazed into your old casting. They are $70.00. If u have someone that is good at welding he should be able to do it but it does take a lot of heat. Make a jig to put it in so you can get it lined up straight and it should work great. Sharp's www.oldjd4u.com. Good luck
ChuckW
12-19-2004 16:50:40
yes, I've attempted a repair on one and it's a bear. The pipe is brazed to the inside of the cast iron flange and it take a ton of heat to do this. Also the pipe is a different size than is available at local muffler house. Personally I would say to go to salvage yard and try to find a good replacement. They should be quite common and you may even check ebay for one. I'm not sure if there is an after market manufacturer.
