jdemaris
12-20-2004 12:40:06
Re: Deere Engine Swap in reply to Bob Santilla, 12-20-2004 07:07:48
The engines are pretty easy to work on. One trouble spot though on the four cylinder engine you are working on. It has twin balancing shafts. They are not used in the 3 and 6 cylinder engines, and for a while, Deere tried leaving them out of some of the fours - but that resulted in too much vibration. Four cyliner engines have inherent balancing problems, whereas 3s, 5s, and 6s don't. Deere's smaller engines use balancing shafts and larger ones use balancing gears or boxes. Anyway, what tends to happen is these engines get "in frame" engine jobs that usually include new rod and main bearings, pistons, sleeves, valve job, oil pump gears, etc. What is often overlooked is the balancing shafts and bearings since you can't replace them easily. When they get worn, the engine will not hold oil pressure once it gets hot. Sometimes you have to run a machine for half an hour before the problem shows up. So, keep that in mind. You can look at the shafts once the oil pan is off. These shafts don't come in the engine kits. Also be sure to check the oil pressure regulator and seat (they get hammered and worn) and also, when doing a valve job, installed valve head depth is critical for cold weather starting. Simply regrinding valve seats and refacing valves will usually lead to a poor starting engine that will skip, miss, and smoke until it gets hot. Original heads do not have valve seat inserts (unless it's a turbo). So, usually the way to go is to have the heads bored for hardened seat inserts. That way the installed valve head depth can be done correctly.
