420 power steering
Henry James
12-19-2004 14:48:00
Good Evening, I'm looking for a power steering belt pulley for the saginaw steering pump for my 58 420W. If anyone has one for sale please let me know. 304 749 8503 or post your # and I'll call you.
Best Regards Henry!
Henry J
12-19-2004 19:11:13
 Re: 420 power steering in reply to Henry James, 12-19-2004 14:48:00
Henry
I got mine from JD, but that musta been 2 years ago.
As I recall, the JD number is still showing since the ole girl is on vacation most of the time nowadays. But dayum, it is dark out and 15 degrees in the barn right now. Let me know if you want me to check it out.
Henry James
12-20-2004 07:26:22
 Re: 420 power steering in reply to Henry J, 12-19-2004 19:11:13
I would be thankful with any help you can give me on the part #. My pulley was missing when I got the tractor. I found a good pump on this site from nice fellow in ID.
Best Regards Henry James!
Cecil R. Chandler
03-26-2006 16:48:29
 Re: 420 power steering in reply to Henry James, 12-20-2004 07:26:22
I own a 1958 420T slant steer John Deere. I am in
the process of restoring it. I would like very much to put a factory power steering unit on it.
If anyone has one for sale, please let me know.
Thanks very much.
Henry J
12-20-2004 17:23:59
Henry
I don't know who made the pumps but there were two different kinds and each one had a different pulley and belt.
If you got the pump with the double groove pulley on the shaft the Belt should be T12267T.
If you got the pump with one groove in the pulley the belt no should be T10552T.
Your JD Dealer should be able to pull up the part screens to see what may fit. Mine even enlarges them and prints them out if we have to consternate on something.
I did not hit you with the majic serial number split because those units can be mixed and matched and were through the decades.
