730 Transmission
Bob Lewis
12-19-2004 08:52:52
Where does the transmission vent on a 730 diesel? Oil is leaking past the new axle seals and bearings, adjusted to specifications. Pressure seems to be building in transmission case. Thanks.
Ben.So.Tex
12-19-2004 15:48:36
 Re: 730 Transmission in reply to Bob Lewis, 12-19-2004 08:52:52
Your crankshaft seals (clutch side) may be worn and engine oil is seepping past them. Had this happen on my 50, replaced the seal and it is fine now. DON'T throw the old seal away when you take them out, JD may not have them in stock, you can cross reference them at your locaL auto parts store and they can get you the correct ones... Good luck Ben
RalphinWI
12-19-2004 11:44:04
If the construction of the 730 is like the A, the seal is at the inboard end of the axle. If the seal fails, a cavity below the axle and between the seal and dust seal (felt) at the outer end of the axle fills with oil. If this cavity is not emptied when the seal is replaced oil will continue to seep through the felt seal.
Bob
12-19-2004 09:57:27
The tranny/rear end vents around the gearshift lever.
