Broken brake Pedal
smith
12-19-2004 07:19:07
....Have pulled a boner and broke off the right brake pedal on my 1020 while putting on the loader. After ordering a new one I figured replacing it would be easy,I guess not. After taking off the snap ring I can"t seem to be able to remove the roll pin which goes through both pedals. Do I need to remove the pressure off of the brake system to do this? Can anyone walk me thru this procedure..Thanks in advance...(I read this site all the time to gather info)....
david val
12-20-2004 04:10:52
 Re: Broken brake Pedal in reply to smith, 12-19-2004 07:19:07
the pin is probably rusted to the brake valve housing. don't hit the pin too hard as you may brake the 'ear' from the housing. you can also 'mushroom' the end of the pin so it won't be able to pass through the housing.
the pin may also be rusted to the pedals. if so it rotates with pedal movement.
in any case, penetrating oil and patiance are the main tools for this job.
david
Jim Dunn
12-20-2004 06:44:18
 Re: Broken brake Pedal in reply to david val, 12-20-2004 04:10:52
If you are just a little bit handy with an accetylene torch, you can put on a small tip and heat the metal around your roll pin, (Caution, not the pin). Sort of work the heat so as to drive the expanding metal away from the pin in all directions. This works wonders for rusted old metal fits. Be ready to drive out the pin while there is plenty of head differential between the pin and other parts. Good Luck.
Jim
