4620 rear tires
MK
02-11-2004 16:02:01
I think this year it is time to put new tires on my 4620. My question is, I have bias 18.4x38's inside and out, to get more traction would I be better getting rims to put 20.8x38 bias on or put 18.4x38 radials on? Even when I had lots of lug left, I was slipping too much in most fields on second tillage pass. What is a good brand of radial? I have been told radials have weaker side walls. I pull a 5x16 plow with the duals off to fit in the furrow so this would be the most stress the tires would get. Wonderin if that's a story or truth? MKinAB
JDBert
02-12-2004 07:22:22
 Re: 4620 rear tires in reply to MK, 02-11-2004 16:02:01
We put 18.4x38 Super all traction field and road 23 degree radials on the mains and moved the field and road bias plys to the duals. This made a whole new tractor out of it. I would caution you on going to the 20.8x38's, what you need to remember is that this will make your speeds faster. So if right now on 18.4's 5th works good, if you go to 20.8's 5th might be to much for your horse and 4th will be too slow, and you'll either pull the crap out of it or burn alot of fuel.
KG farmer
02-11-2004 18:23:23
Myself i would get bigger rims and go with 20.8 38 good year, firestone, or michelin tires. They would give u unbleieveable traction in any condition with that big of 2 wheel drive tractor.
Hope this helped u out a little.
Joe NY
02-11-2004 17:39:24
For radials I would say that you can't go wrong with Firestone or BF Goodrich. If you go Firestone don't get the cheaper 23degree ones, get the more expensive all traction 23 degree or 23 degree deep tread. If you change size or not I would suggest radials.
