1956 620 wiring?
david lee
12-18-2004 16:30:42
I am in the process of rebuilding a 620 and am in the final stage. And ready to start the old girl. I rewired it like it was when I got the tractor. But am uncertain if it was wired correct when I bought it.( pretty rough shape )I have an IT manual for it,and I have a manual for the JD 60. The it manual has no info on the wiring at all.And the manual for the 60 shows the wiring but is not the same gauges. Any help or descriptions of the wiring would be a great help,and time saving on the tail and error guessing. Thank you in advance Dave Lee
Steve Chambers
12-27-2004 05:18:01
 Re: 1956 620 wiring? in reply to david lee, 12-18-2004 16:30:42
David, you didn't state wether you changed your 620 to a 12 volt system or left it a 6 volt as it was when new. I've just done the same thing to my 620 it was converted before I bought it to a 12v system. I'd be glad to help but need to know what we are working with.
david lee
12-27-2004 06:53:06
 Re: 1956 620 wiring? in reply to Steve Chambers, 12-27-2004 05:18:01
The tractor is set up for 6v. I wanted to keep it original. but when I put a new coil in the old one
or the one that was on there was a 12v. I think that I have found the problem. I had been checking the system with a test light. I remembered to finally bring my multi meter home.And when I checked the system I found that the resistor was bad. It was so rusted up that there was no continuity. I did order a new one. But wonder if I should just use a coil with an internal resistor instead.
Steeve Chambers
12-28-2004 00:32:54
 Re: 1956 620 wiring? in reply to david lee, 12-27-2004 06:53:06
Are you planning to use solid state ignition or use points? The points would benefit from a new resistor, hotter fire while cranking. But the solid state will be ok with an internally resisted coil. Hope this helped
