3010 load control yoke
Sammy
02-11-2004 15:37:15
The load yoke front pin has about 1/8 inch free travel up and down. does the yoke have a bushing? I will replace the pin when I do the rear bushings and shaft. Its cold out now so I will have to wait on warmer weather. how does the front pin come out? dark in shed I could not see a set screw? Any tips or tricks would be welcome! thanks in advance Sammy
Sammy
02-11-2004 18:15:53
 Re: 3010 load control yoke in reply to Sammy, 02-11-2004 15:37:15
Thanks guys I figured there would be someone with experence in this area. This board is great! thanks again Sammy
chris
02-11-2004 17:52:40
That little bit won't hurt a thing, I changed my first one because of that too, wasn't any better with a new one. And I changed a bunch of seals on many tractors without replacing the front one with no problems. chris
Brad
02-11-2004 17:38:06
Think its pressed in there. Its not supposed to be a snug fit because it has to move for the load control to work. When I did my rear shaft and seals I just let the yolk swing down out of the way and did not worry about getting the front pin out. hope this helps
