Don, it was originally POSITIVE grounded, how is your battery connected now??? If its been reversed and the ammeter leads were not swapped, it would read bass ackwards. I would start all over with the battery at Positive ground,,,,, ,Then again polarize the Generator (you actually polarize it, NOT the VR),,,,, ,and see what she does then. Many Voltage Regulators (and cutout relays) will work at EITHER Pos or Neg ground, while others may not, and that might be a part of your problem. If it only has a 2 wire Cutout Relay and not a 3 wire Voltage Regulator, they wont work wired backwards (see below). Also, you say "Voltage Regulator" so has it been rewired from a simple 2 wire cutout relay and light switch Field control to a full fledged 3 or 4 wire VR ????? ???? Does your light switch have like Low and High Charge and Light settings????? (those are for the cutout relay and switch controlled Field systems) A typical Cutout Relay has but 2 terminals (BAT and ARM (or Gen)), while a Voltage Regulator usually has 3 (BAT ARM FLD) terminals. What do you have??? Its easy to tell if shes charging independant of the VR or Cutout Relay as follows: First be sure the belt is good n tight and the Gen and VR (or relay) is well grounded. ALSO, the BAT terminal on the VR or Relay MUST read hot, as its wired to the ammeter and thats the path for the battery to receives its charge. If its not, she cant ever get connected to the battery to charge it. With it running, temporarily by pass jump around (connect BAT and GEN (or ARM) terminal together) the Cutout Relay and see if she charges. If so, the relay is bad or wired wrong. Likewise on a VR, jump the BAT and GEN together to tell the same. (Either by passes any bad VR or Relay operation) If she still dont charge, temporarily connect the Gens Field terminal to ground. If it charges then, the wires missing or open from the Gens Field up to the Light Switch, or the switch is bad or not grounded (if on a cutout relay system) or else the VR is bad or not grounded or wires missing from the gens Field to VR's Field terminal if on a VR system). See if youre at POS or NEG Ground,,,,, ,wire her Positive,,,,, ,,Repolarize the Gen,,,,,Try the by pass and Field ground checks above,,,,, ,post back what you have (VR or Relay and Ground) and your findings and any questions and I will try n get her charging. You may simply have to reverse the Cutout Relay (wont work if wired wrong) or get one of the correct voltage and ground???? Lemme know Good Luck n God Bless John T in Indiana
