Dead Gator HELP !!!!
JDMAN60
12-18-2004 08:13:01
My Gator won"t start all of the electrical circuits work except for the starter. I started testing the safety switches and the one on the transmission if I take my grounded tester and touch the wires coming from the dash ( I think that is where they go ) the motor starts to tunr over and if I turn the ignition switch to run position it will start. I have tested the ign switch and thought it was bad put new one on and the same thing. dealer says probably the start relay but no one has one. I need a wiring diagram if anybody has one and can scan it and email it to me I would appreciate it very much. Thanks Willy
Henry J
12-18-2004 09:31:56
 Re: Dead Gator HELP !!!! in reply to JDMAN60, 12-18-2004 08:13:01
Willy
I would guess that if you ran those two wires that you are shorting to get the starter turning down to where (if they do) they connect to the sensor you will have the culprit.
Whatever it turns out to be (i would guess the neutral safety switch, short those two leads out at the source, and if she cranks up, you got the problem. Next check for trash and proper adjust ment of the sensor before you get a new one.
hope that works and happy holidays
Hoss
12-27-2004 20:02:20
 Re: Dead Gator HELP !!!! in reply to Henry J, 12-18-2004 09:31:56
I am having a very similar problem with my gator. Could you tell me where this safety switch is located?
Any help would be appreciated.
