Changes in Safety Standards
Gary Myers
12-18-2004 03:25:38
I had a chance to look at an old JD60 brochure recently. It sure brought back a lot of memories, but one thing that made me laugh was the way safety was looked upon back then. John Deere made a big point of how handy it was that you didn't actually have to be sitting on the tractor to move it. You could easily "reach the hand clutch from the ground when hooking to implements". They show a picture of a guy standing behind the tractor with his hand on the clutch presumably backing it up to a hitch. I guess people were smarter then, that could kill you today!
John Van Valkenburgh
12-19-2004 13:07:40
 Re: Changes in Safety Standards in reply to Gary Myers, 12-18-2004 03:25:38
Last summer I was mowing in a horse pasture late in the evening and I ran out of gas. Tried to make it back towards the shop but the ol 50 does not give you more than 30 seconds or so warning that its running out.
Walked down to the shop and brought back a couple gallons. Put the gas in and reached over to hit the starter pedal with my hand to crank it over.
I pride myself on how fast my 50 starts.
Now I saw it was in 4th gear but I knew I disengaged the clutch before I got down. Well I thought I disengaged the clutch.
Off she goes towards the fence. Luckily I had the sense to get out of the way first and then come from behind and switch it off.
Needless to say I make certain that its out of gear and the clutch is disengaged before I ever crank it up from the ground.
I've also gotten in the habit of putting it in neutral when getting off to walk in front of the tractor when its running. I've heard stories about the clutch failing in such a way as to engage.
Overall though I think safety is knowledge of what the hazards are and common sense. I sometimes do stupid things, but generally I don't do them twice.
John
1953 Model 50
jdat jared
12-18-2004 20:03:57
i think that every one needs to be reminded about farm saftey every now and then.
this last september, one of the neighboring farmers was killed in a tractor roll over.
i believe that it is best to use common sense. if something is moving, stay the h--- a wayfrom it if you can help it, carry loads low, and keep your loose clothing tucked in.
jared
ChuckW
12-18-2004 16:57:53
just bought a landpride FDR2572 rear discharge finish mower today. Read the operators manual, the first 6 pages are dedicated to safety. Little different than 50 years ago...
msb
12-18-2004 15:03:10
I don't think they were smarted back then.I remember several instances back in the 40s and 50s of farmers getting killed when the old hand clutches were operated from the ground.I rebuilt a Deere 70 that ran over an old woman and crushed her pelvis.Crankshaft thrust washers were almost completely gone and it jumped in gear when she got off to open a gate.Had a neighbor who was killed when an unguarded PTO shaft grabbed his pants leg.When he was found, the PTO shaft was still wrapping him around the shaft,still beating his head against the tongue of the implement.I personally knew of two farmers that lost hands in corn pickers.
Bob Collins
12-18-2004 07:08:28
The sales brochures were just that, selling tools. After you had purchased the tractor if you read the operators manual, you would see the recommendation to back closer than needed to the implement, then from the ground, operate the clutch to move the tractor AWAY from you to the right location for hitching. This doesn't disagree with the posts below, just added to them.
1rooster
12-18-2004 05:26:22
It is of like Paul Harvey said a few years back in regards to politicians, he said they were well educated, but lacked in two of the senses, Horse and Common. I agree with Believer45, our country is in the state it is today, because no one wants to be responsible for their own decisions, if it turns out to be a bad one.
ChuckW
12-18-2004 04:25:59
Don't kid yourself, in the back when good ole days there were no safety standards. Your common or uncommon sense and ability to jump out of the way was all you had. I compare safety to the 55 Chevy where they designed a point in the center of the steering wheel. Looked good but consider the injuries this caused. You were own your own back then, no safety shields, ie. I'll take it like it is now....
I Bleed Green
12-18-2004 03:46:28
People back then did what people can not do today. Take time!!
F-I-T
12-18-2004 11:04:28
 Re: Changes in Safety Standards in reply to I Bleed Green, 12-18-2004 03:46:28
I'm not too sure people were any different with regard to safety back then. The guys who were always in a hurry generally had a finger or two missing if they were lucky, and a were missing a whole arm, leg, or a had shiny casket if they were not.
We had an accident prone farm family in our neighborhood, and after a twenty year run the results were:
One arm missing - Grandad (cornpicker)
One burned 80% - Dad (waterheater lighting next to 5 gallons of gasoline)
One death - Son, 16 yr old (overturned a Farmall "H" with loader and load high in the air in the ditch)
It always pays to go slower.
Frank
Believer45
12-18-2004 03:59:18
Take time - plus actually use that gray matter between their ears and THINK about what is going on.
Also - back then we were responsible for what we did right and wrong. If we were stupid we were responsible for the result.
Getting off my soap box now.
Sorry - Dave / Believer45
