GL Ratinf for Tranny Oil
Henry J
02-11-2004 15:02:51
I have pretty well kept up with all the posts about the noisy tranny's and using 140wt in them. However, I had been reluctant to use the GL 1 in the Dubuque because of the hypoid cut gears in the differential. So I have been using 85-140 GL5.
While cruising the local farm store today I ran across straight 140 with a GL 4 rating. This appears to me that it may be a good compromise and work (technically) better for all the gears in the Dubuque trans/differential than the GL 1 140 wt.
Am I on the right track?
Clooney
02-11-2004 15:22:31
 Re: GL Ratinf for Tranny Oil in reply to Henry J, 02-11-2004 15:02:51
Henry, GL-4 is a good gear oil,, It has some EP additives for high gear tooth shear loads but not an excess amount like the GL-5,,85-140's.. I think most GL-4 gear oils are for marine applications & are blended to handle moisture in the oil.. It probably isn't as sticky as the GL-1 gear lube but will be much better than GL-5..
~If I were personally going to use an EP type gear oil in an old tractor it would be the GL-4..
~Remember when your tractor was sold & used for farming there were no EP additives in gear oil at that time..
[email protected]
