48 John Deere
Charlie Chan
12-17-2004 06:26:14
Recently purchased a 48 A with what is supposed to be a later model 60 engine.Where is Serial number located on 60 engine?Pulled the carb apart and cleaned same, it is a two barrel carb.The engine runs good under a load, but surges when not loaded and runs roughly.Have changed points and condensor, and think that both cylinders are hitting good.My only other experience with JDs was a 41 B and a 36 G both on mags.They ran perfectly compared with this.Got any ideas?Thanks
Goodwrench
12-17-2004 08:02:03
 Re: 48 John Deere in reply to Charlie Chan, 12-17-2004 06:26:14
If it has the Duplex Carb, you have a "60" head, which will bolt up to the late "A" block. Both the "60" and late "A" uses the same block specs, although there were changes to the casting between series. If you have a parts book, compare the part#'s for the block & head (if you are really interested)
If the tractor runs good under load but surges at low-idle, I'd first look at the governor linkage & ensure it is adjusted per spec. Since your "A" is a convert, you will need to improvise a bit as the speed lever connection is different for the "A" from the "60"
If the linkage isn't to blame, you may have operating sleeve / fly bearing problems in the governor. To test governor action, operate the carb butterfly manually after disconnecting the governor linkage. While manually increasing the RPM's at the butterfly, you should feel the linkage move as the governor tries to close motor down.
Good luck
seppenfield
12-17-2004 13:05:56
 Re: 48 John Deere in reply to Goodwrench, 12-17-2004 08:02:03
I had a 50 a and had the same trouble. Found out the body of the carb that the stem rides was wore out. had a bushing machined and all is well!!
Mike M
12-17-2004 07:30:23
When someone converted those all they need to do is to bolt on a cylinder head from a 60 and use the 60 carb. and intake the later A's like 50,51,52 allready had the same block as a 60 on your 48 they may of swapped the block and added one more bolt or let it out.The frame side rails usually needed some cutting or bending to clear the head. On that carb. does turning any of the 2 idle adjustment screws make a change ? If not you still have some blockage in it.I also would not rule out a bad left hand cam bearing as those models have a problem with them.
johndeerejosh
12-17-2004 08:41:12
 Re: 48 John Deere in reply to Mike M, 12-17-2004 07:30:23
yeah try the idle adjustment screws. it does surge at an ilde right.
