1935 JD B crank specs
Smitty of Cal
12-16-2004 22:08:57
A friend has a 1935 JD B and needs to know the stock journel sizes of the crankshaft and what it the maximum it can be turned to.
Thank You
Smitty
Duane Larson
12-17-2004 06:06:20
 Re: 1935 JD B crank specs in reply to Smitty of Cal, 12-16-2004 22:08:57
Smitty,
JD Field Service Bulletin 167 gives 2.500"-0.001" for the crank at the rod bearing, and 2.250"-0.002" for the crank at the main bearing for B1000 - 59999.
Talk to your machine shop about how much it will take to clean the crank up, and if they can re-babbit if necessary to fit the processed crank.
Smitty of Cal
12-17-2004 17:53:09
 Re: 1935 JD B crank specs in reply to Duane Larson, 12-17-2004 06:06:20
Thank You Duane
Smitty
