2350 smoking?
paul d
12-16-2004 08:54:28
just bought a 2350. man said the head was blown.he said white smoke came pouring out of it.the starter was taken out to be used on something else so being in a hurry i pulled the head off.i found nothing wrong. anybody have any ideas or how to proceed.it is a deisel.
seppenfield
12-17-2004 13:00:08
 Re: 2350 smoking? in reply to paul d, 12-16-2004 08:54:28
It might be an injector..... raw fuel smoke can look like water smoke coming out of the stack
Mark57_420
12-17-2004 04:44:33
Ditto on the pitting. We had the same problem on a 6600 combine many, many years ago with the exact same symptoms.
PJB
12-16-2004 12:14:47
I bet you almost anything it's sleeve pitting..... I'm doing a 2030 right now that has sleeve pitting.... The JD have wet sleeve engines and over time if you don't change the anti-freeze and add adative to it it will pit the bottom of the sleeve and anti freeze will get in. Check the crank bearings.... if they are good you can do a in tractor rebuild if not you will have to pull the engine out.
Indydirtfarmer
12-16-2004 09:09:54
Was the smoke coming from the exhaust? Or the crankcase breather?
My initial reaction was that you MIGHT have a hole in a cylinder sleeve. Those engines are proned to "wet sleeve pitting". The coolant becomes "acid" over time. That, combined with a tendency to cavitate, the cylinder sleeves will get pinholes near their base, causing coolant to dump into the oil pan and/or the combustion chamber. Initially, it will give some of the same symptoms as a blown head gasket or a cracked head.
Pull the oil pan, then pressurize the cooling system. (10 to 20 lbs should do the trick) make certain you have liquid in the coolant system also.
If this is your problem, you will see fluid appearing around the base of the cylinders, inside the crankcase.
Time for a complete rebuild.....
I've seen a couple 219/239 cu. in. Deere engines do exactly this same thing. John
paul d
12-16-2004 09:32:03
 Re: 2350 smoking? in reply to Indydirtfarmer, 12-16-2004 09:09:54
thanks for the response. he said smoke was from the exhaust. i'll pull the pan and see what i find.
Indydirtfarmer
12-16-2004 09:59:57
 Re: 2350 smoking? in reply to paul d, 12-16-2004 09:32:03
On both the engines I was involved with that suffered from sleeve pitting, the holes were right at the bottom of the sleeve. Right where it fit into the casting above the crankshaft. John
