4020spin-on oil filter ??
mike
02-11-2004 12:02:20
Is anyone aware if there is a kit out there to make a spin-on filter work on a 4020D Either on the block or on the oilpan. We are overhauling ours and was just wondering about the possibility. It's such a pain to change filter the way it is. Hydraulics are on the dash not sure of the year. Thanks for your help.
WTW
02-11-2004 14:23:57
 Re: 4020spin-on oil filter ?? in reply to mike, 02-11-2004 12:02:20
Mike, If you really want a spin on oil filter bad enough, yes there is a way to do it. The same engine that you have in your 4020 was also used in 105 combines and they used a spin on oil filter. To change your engine over to this setup you will have to swap the engine oil cooler assembly and base which contains the spin on filter base. You will also have to swap the engine oil pump as the original tractor oil pump carries the filter base now. I have many 4020's running around with this setup only because they were old sick gas tractors that were repowered with diesel combine engines. I have to agree with Bob and ask the same question as what so hard about changing the filter it has now? Its your option if you want to go to the troubles. Good Luck, Dave W.
Bob
02-11-2004 12:19:37
I am not aware of a spin-on filter kit for the 4020. The way the system is set up, it would be tough to do with the original engine block.
Really, though, what's so tough about changing the original filter? You've already got the oil bucket right there from draining the pan, and it only takes a couple of minutes to undo the four filter cover bolts.
