Front weight for a 50
rej
12-15-2004 11:18:05
I need to add some front weight on my 50. Can anyone tell me if the one piece weight that mounts on the front of a 40 will fit on a 50. Also how much do they weight. thanks
donwisc
12-17-2004 08:22:13
 Re: Front weight for a 50 in reply to rej, 12-15-2004 11:18:05
I cut some L shaped wts out of 4 inch plate that I used on a 730 before I sold it. They are avail and if you are interested Email or call at 414 543 2563. Milwaukee area
BushogPapa
12-15-2004 16:57:33
Go to a scrapyard and look for some 1" thick steel plate.. You can make a lot of weights for what one "50" weight will cost..!! You can make them to fit the front or along each side--or both.... "Pier plates" from a bridge are good...about 1 1/4" to 1 1/2" thick.. There is usually a 1/4" thick Lead plate that they lay on that is a dandy weight in itself..
JYD
12-15-2004 13:01:54
The front weight for the Model 40 will not fit on your Model 50. There is a two-piece weight set designed for the Model 50. Each L-shaped piece mounts with two bolts, one on the side and one on the front. These sets are scarce and hold onto your wallet if you find one.
JYD
12-15-2004 13:07:26
 Re: Front weight for a 50 in reply to JYD, 12-15-2004 13:01:54
The part numbers for the weights you need are A5347R and A5346R (you will find them on page 10-2 of the Model 50 parts catalog). Be aware, also, that the two-
piece weight set for the Model 60 will not fit on the Model 50. Good luck!
