#45 Loader Piston Rods
Dave in CT
12-15-2004 08:44:33
I've an early Series 1 #45 loader. There's a fellow on ebay who's selling a pair of piston rods for that he thinks will fit this loader. The rods are in a case marked PN: AC-12363. I'm wondering if these will fit the lift cylinders on my loader.
I Bleed Green
12-15-2004 15:59:14
 Re: #45 Loader Piston Rods in reply to Dave in CT, 12-15-2004 08:44:33
I have a 45 loader parts catalog. PC484
AC12363 is the bucket cylinder rod. (1963- )
(note) bucket cylinder, not lift cylinder.
The lift cylinder part numbers are. Y 1816 C ( -1957. C 10507 C (1958- ) and AC 11480 C for 3010 and 4010 tractors.
Henry J
12-15-2004 10:30:19
Dave
I am assuming that you want to replace the rods becuase they are too pitted or bent?
If they are just leaking new seals are available.
Just checking
happy holidays
Dave in CT
12-15-2004 15:09:50
 Re: #45 Loader Piston Rods in reply to Henry J, 12-15-2004 10:30:19
Thanks Henry - yeah one rod in particular was way pitted with rust. I know people get busy but it always amazes me when folks are too busy to get the rods all the way retracted. That plus a little grease would've saved the rods. I'll look into rebuilding them with the chromed rod stock and new seals.
Mike M
12-15-2004 10:06:35
I don't have my parts book handy to give you a complete answer,but another option is to go to a local hyd. cyl. shop and buy the chromed rod stock. These are very easy to make as the ends only need a hole cross drilled to accept a roll pin that is all that holds them on. Back when I did one this was very cheap to do compared to buying new ones.
Dave in CT
12-16-2004 16:29:48
 Re: #45 Loader Piston Rods in reply to Mike M, 12-15-2004 10:06:35
I've a couple of questions about getting the chromed rod. Did you buy just one length and cut it and drill the holes for the roll pins yourself? Do you remember what the specs on the rod you bought were? I just held up a ruler to the rods and know they are in the 1.25" ballpark. How long were the rods? Did you have the shop do the cutting and drilling of the holes? How did the expenses breakdown? Ballpark costs are O.K.
Thanks again for your time,
Dave
Mike M
12-17-2004 11:56:47
 Re: #45 Loader Piston Rods in reply to Dave in CT, 12-16-2004 16:29:48
I might still have a complete old pitted one laying around I can measure it. I did it all myself just touch the surface with a grinder where you want the hole to remove the chrome then center punch and drill,I would recommend a good drill press or mill to get them straight in the center. Some of mine were off a little but it still fit.
Dave in CT
12-17-2004 15:17:59
 Re: #45 Loader Piston Rods in reply to Mike M, 12-17-2004 11:56:47
Thanks. I'm having a hard time finding a place that will sell chromed rod stock. Can you recommend anyone on the web?
Tom in WIS
12-18-2004 07:59:56
 Re: #45 Loader Piston Rods in reply to Dave in CT, 12-17-2004 15:17:59
My company rebuilds hydraulic cylinders all of the time.
And myself being somewhat of a JD fan, I just got a JD 45 loader in my possesion.
I would be willing to take 1 of my cylinders apart to make you a set of rods.
Otherwise we use a company called "Bailey International" for a lot of our hydraulic components. ( http://www.baileynet.com/ )
I know for a fact that they sell chrome rod. It can be very expensive.
In any case let me know if you are interested.
Mike M
12-17-2004 15:58:22
Dave; I searched high and low in the shop I can't imagine that I used both of those old ones in other projects ? I don't have any measurements. Here's the phone number of the place I bought mine GSC Enterprises Inc. 419-747-3363 it was a long time ago I bought mine and the original owner has passed away hopefully they are still good people.That's in Mansfield OH. If they can't help try this other place Advanced Cylinder 419-289-0538 I have never delt with them ? You are probabaly going to have to tear one apart to get the right parts. Back when I did mine (15 years ? )new ones from deere were guessing $150 each. I bought 2 rods and all the seals for $100 if you don't want to mess with them yourself, and have the extra $ I'm sure both could do the whole job for you.
Dave in CT
12-15-2004 10:16:25
Thanks Mike. That had crossed my mind but I didn't know the architecture of the pistons. While I'm talking to you, would you know where I can get an inexpensive operator's manual and parts manual?
Thanks again,
Dave
Mike M
12-15-2004 10:38:13
 Re: #45 Loader Piston Rods in reply to Dave in CT, 12-15-2004 10:16:25
I got mine from Deere a few years back.I have seen an 800 # posted here to call the catalog department see if you can find it in the archives ?
Bob
12-15-2004 10:45:06
 Re: #45 Loader Piston Rods in reply to Mike M, 12-15-2004 10:38:13
Deere manual phone #... 1-800-522-7448.
Operator's Manual... OMC12410 @ $30.00.
Parts Manual... PC484 @ $30.00.
