G sparkplugs
Daniel Chestnut
12-14-2004 18:54:27
I finished putting the head on my 1952 G tonight and I realized I hadn"t got spark plugs for it. It had Champion D-16 s in it. I was just wondering what would be the best plug to get for it? I"m just going to run regular gas in it.
buickanddeere
12-17-2004 13:57:24
 Re: G sparkplugs in reply to Daniel Chestnut, 12-14-2004 18:54:27
Autolite 3116 non resisitor plugs are supposed to be close to the 386 resistor heat range.
Gpower
12-15-2004 09:58:54
If you go with the 388 autolites, you will have to buy plug adapters to fit the 14mm plug. The d-16's are 18mm. I do recommend the autolites 388 though, good plug.
Gpower
Gpower
12-15-2004 10:07:43
 Re: G sparkplugs in reply to Gpower, 12-15-2004 09:58:54
Retract that statement, the 388 is still the big 18mm plug, if you want to go to a hotter plug, you will the adapters. You can use a wider range of heat plug with the adapters, and eliminate a lot of fouling out with the smaller, hotter plug.
Gpower
John51
12-15-2004 02:17:30
Are you really going to run it hard for hours? Unless you are planning to use it as a regular work tractor I would strongly recommend you go with a hotter plug. I run Autolite 388 in my 730 and 4020. Try them.
Daniel Chestnut
12-15-2004 05:29:08
 Re: G sparkplugs in reply to John51, 12-15-2004 02:17:30
No, I"m not going to work it everyday. Hardest work it will be seeing is pulling a plow every once in a while.
Wimpfarm
12-14-2004 21:28:40
Try AC 86"s or autolite 386 .
Hoosier JD
12-15-2004 15:18:50
 Re: G sparkplugs in reply to Wimpfarm, 12-14-2004 21:28:40
Since I put 388's, electronic ignition (also a hotter coil that came with it), and solid Accel copper wires....I've not had any plug fouling. Later, Mike
