4010 steering
JD DAYS
12-14-2004 18:00:14
my 4010 steers hard to right until it has been turned all way then it is fine for a while then
it will do it again could any one help me with what is going on or what needs to be done to repair this
Mark / WI
12-15-2004 05:18:15
 Re: 4010 steering in reply to JD DAYS, 12-14-2004 18:00:14
My 4010D was doing the same thing until I changed the transmission/hydraulic oil and filter. I also found I only had 4 gallons of oil when it was supposed to have 11 gallons. If you don't want to change it at least check it to make sure it has enough.
JD DAYS
12-16-2004 12:52:18
 Re: 4010 steering in reply to Mark / WI, 12-15-2004 05:18:15
THANKS MARK/W1
I took your suggestion today and it worked
THANKS JD DAYS
