First reduction gear change
old-joe
12-14-2004 16:27:22
Would like to know if the 720 diesel first reduction gears are the only ones that can be used to slow down 1st gear in 70 gas pulling tractor? Or can a 70 diesel, 720 diesel or 730 diesel gears be used. Are the reduction gear and the clutch gear all you need to make the swap?
Thanks in advance, Old Joe
buickanddeere
12-17-2004 14:06:13
 Re: First reduction gear change in reply to old-joe, 12-14-2004 16:27:22
With some machining the 1st reduction gears from a 70D can be jammed into a 70G. Cuts ground speed to 7/8 of origional in all gears. Goodness only knows what different bull gears and differential gears have been machined on the same center spacing but with different tooth counts. Mother Deere liked to share the same parts and production line equipment across as many models as possible to cut costs. Govenors, power steering, ignition/electrical,engine,cooling and some transmission parts will swap across many "unrelated" two cylinder models.
mike brown
12-15-2004 05:32:23
There were some tractors made with low speed transmissions. They had a shift pattern of 124-356 I believe. I had a 720D with it and it was really slow in the low gears. I think it was acomplished with adifferent gear on the left side of the tansmission case that reduced the speed of one of the tranny shafts. might be available at a bone yard.
Dale in IN
12-15-2004 07:28:51
 Re: First reduction gear change in reply to mike brown, 12-15-2004 05:32:23
Mike:
According to the service manuel on the 720D/730D changing the gears on the left side only affects the 3rd & 5th Gears. The other change has to be done inside of the transmission and that changes the 4th & 6th gears. I have a 730D and it has the fast transmission in it. The shift pattern is 1-2-3-R on the left side and 4-5-6 on the right. We compaired it to a 720D last fall That has the other pattern on the shift housing and the Reverse gears were the same speed. I have often wondered about changing the first reduction gears and if there was such a change. And would there be enough clearence in the housing or cover to allow for it. It would require a smaller gear on the crank shaft and a larger gear on the input shaft. One or two teeth would make quite a difference. If so this would slow all of the gears down.
