5010 value
curt_sw_ia
12-14-2004 15:41:24
what would one expect to pay for a 1963 5010 with about 4000 hours on it. 2000 on original motor, and 2000 on 5020 motor. original is included in purchase. owner switched because he wanted the turbo. has factory direct mount duals, not bolt ons, and also has mounted dozer blade...a ball park amount would be appreciated so i know if i"m getting a decent deal or not
Mike M
12-15-2004 10:22:45
 Re: 5010 value in reply to curt_sw_ia, 12-14-2004 15:41:24
A tractor jockey once told me that those 5010's and maybe even 5020's should hold the worlds record for throwing rods out the side of the block. I should also be a safe bet that most he had seen had aftermarket turbos on them.
JD 5020 guy
12-14-2004 21:18:10
You said he switched engines because he wanted a turbo. The 5010/5020 never had turboes from the factory. Could be a 6030 engine or just an add on turbo. Around here a normal 5010 is worth about $5,000. But with a turbo, probably less unless its a 6030 engine.
curt_sw_ia
12-14-2004 22:34:52
 Re: 5010 value in reply to JD 5020 guy, 12-14-2004 21:18:10
now that you say that, it got me thinking....so i pulled out my JD books and did some reading. i know it isn't the turbocharged and aftercooled 6030 motor because it doesn't have that style of manifold on it. the man told me that part of the reason he switched other than wanting a turbo, was that going from the 5010 to 20 motor switched injector types. he wanted the pencil type injectors. oh, and yes, in case you were wondering, i guess for lack of a better term, this guy is kind of eccentric.
