JD 316, Valve lash cap is missing, assumed in oil
Tommy H
12-14-2004 08:05:25
I got this 1988 316 2 weeks ago, and go it runninf, but it had a bad valve noise. turns out the previous owner let the tappets get so far out of adjustment that the valve caps on both intake valves fell off. one was sitting under a valve, the other is AWOL.
I strongly suspect that it is in the oil pan, as the previous owner adjusted the tappet to contact the valve directly.
Question is, how do I confirm it is in the oil pan, is it safe in the oil pan, if not, how do I get it out?
Can't find a flexible magnet long enough to go down the oil fill tube, and cant get the fill tube off to save my life.
I tried to get the drain cock on the side of the engine off. I took the nut loose, and turned the knob till it stopped. but it would'nt come out.
I really really dont want to remove the entire engine just to pop the oil pan off to find that the thing isn't in there.
Any help is appreciated.
oh it is a 1988 JD 316, with a P218 ONAN
Bob
12-14-2004 10:20:11
 Re: JD 316, Valve lash cap is missing, assumed in in reply to Tommy H, 12-14-2004 08:05:25
I can't imagine the valves EVER getting that far out of adjustment. A more likely scenario is sticky valves, and the caps fell off while the valve momentarily stuck.
If the drain-back hole is big enough, you can just about assume the missing cap is in the "basement". There's about a 99.9% chance it would never hurt anything down there, UNLESS it gets in the timing gear train!
Your call whether to retrieve it, or run it the way it is!
