Hydraulic Reservoir Capacity JD A
Phill Snartland
12-14-2004 07:03:25
Can anyone tell me the oil capacity of the hydraulic reservoir on a 48 JD A? I need to know if there is enough oil to run a loader that I'm adding to this tractor.
Also, what is the pressure relief valve setting for the hydraulic system? Will it be adequate for running the loader.
The loader is an old Paulsen that I'm retrofitting to my tractor.
Thanks for your help!
Duane Larson
12-14-2004 14:08:45
 Re: Hydraulic Reservoir Capacity JD A in reply to Phill Snartland, 12-14-2004 07:03:25
Phill,
According to the OM-2002R Operators Manual for A 648000 up, the capacity of the Powr-Trol unit is approximately 5 quarts (when running out of the oil-level opening). If a remote cylinder was used with the Powr-Trol, a procedure is given to add an additional quart for the remote cylinder.
Mike M
12-14-2004 08:00:26
John Deere used the front part of their cylinders as a reservior on the model 45 loader it only had one way packings but had two hoses to each cylinder. If you have double acting cylinders it should work out the same way. On that pressure setting I think somewhere around 800 psi was factory but many have been shimmed up to more.
Phill Snartland
12-14-2004 08:03:51
 Re: Hydraulic Reservoir Capacity JD A in reply to Mike M, 12-14-2004 08:00:26
Thanks, Mike,
This loader has only single acting rams. There's no piston in the rams, only the rod, so there's no capacity for oil storage inside the cylinders ot help with reservoir capacity.
Anyone out there know how much oil is in the reservoir?
Thanks for the help!
Phill
Mike M
12-14-2004 09:27:18
 Re: Hydraulic Reservoir Capacity JD A in reply to Phill Snartland, 12-14-2004 08:03:51
I don't remember how much oil those hold, but I think you are going to have a problem with oil capacity with those cylinders. I bet you are going to have to hook up an extra reservior.
F-I-T
12-14-2004 12:35:29
 Re: Hydraulic Reservoir Capacity JD A in reply to Mike M, 12-14-2004 09:27:18
I agree. I bet there's not but 4 or 5 quarts of "extra" oil in there. Lots of folks plumbed ol Freon tanks with pipe fittings on them for feed the top filler hole on Powr-Trols with oil.
Frank
