730 powershaft adjustment
CFWelles
12-14-2004 04:56:43
I have gone through the process of adjusting the powershaft clutchpack clearances as outlined in the owner's manual for my tractor. Also changed the oil out and put 10W motor oil in there as specified. Shaft still drags hard and I was unable to stop it with a pine 2X4 pinch the other day. Seems to me that this drags too much. I know that I must now go the brake adjustment to stop this, but just wondered from you fellows who know these machines, is it typical for all this drag to occur? I am sure of my adjustment as I used the little lands on the indicator pin just as the manual described to measure movement between engagement and disengagement of the foot pedal. Just wanted to hear that the drag I am seeing is not unusual, otherwise will be scratching my head on this. Have done everything by the book so far. Thanks.
HillBilly in Vegas
12-16-2004 17:38:20
 Re: 730 powershaft adjustment in reply to CFWelles, 12-14-2004 04:56:43
My 620 and 730 will do the same thing happening on your 730. After I adjust the PTO clutch, I have to turn around and make sure the PTO brake is adjusted properly. If the brake is out of adjustment, the PTO will still spin the blades on my bush-hog after disengaged.
CFWelles
12-17-2004 01:51:09
 Re: 730 powershaft adjustment in reply to HillBilly in Vegas, 12-16-2004 17:38:20
Thanks. I was skeptical that everything was together right in there. With yours doing the same thing, I'll adjust the brake and be done with it. Just didn't seem that there would be that much drag in the clutch especially with the light oil in it that JD calls for.
