Argentine 730Ds
mike brown
12-13-2004 19:24:04
Deere built 730Ds in Argentina up until 1969 or 70. They had hydrostatic power steering. A few have been brought to the U.S. Has anyone seen the power steering used in these tractors? I'm curious about what was used, if it is the same as the New Gen. tractors and how they powered it. Whether the gear pump on the fan shaft would cut it or if they used the pump under the transmission. If Hydro. steering needs a variable displacement pump, something altogether different would have to be used.
buickanddeere
12-15-2004 17:41:26
 Re: Argentine 730Ds in reply to mike brown, 12-13-2004 19:24:04
If memory serves correctly those 730 powersteering systems shared parts with a combine steering unit.
Mel
12-13-2004 20:24:42
From what I have seen of the 730's, they had 2 small cylinders laying horizontal next to the frame up front. They had a fan pump with a reservoir mounted directly underneath it. I'm not sure of how the steering was activated. I believe this was done on the later one's produced in Argentina.
