3020 gas won't start
DOUG THOMPSON
12-13-2004 18:40:37
I have a 3020 gas tractor. It is very hard to start, or won't start at all. It has fresh overhual, carb rebuild, new plugs and points, and new starter. Has anyone had an expreince like this that can give me some help.
msb
12-14-2004 20:03:51
 Re: 3020 gas won't start in reply to DOUG THOMPSON, 12-13-2004 18:40:37
First of all, I would install an electronic ignition.Another little trick is to rock the steering wheel back and forth as you crank the engine.That keeps the hydraulic pump from building pressure.
matthies
12-13-2004 19:53:00
Does it start if a second battery is used. If so do yourself a favor and buy another battery, box, cables, and mounting brackets. Most Deere gas and lp burners are hard starting. My brothers 4020 lp always started hard. Put a second battery on and was a different tractor. Well worth the money we spent. chris
Mike M
12-14-2004 05:30:15
 Re: 3020 gas won't start in reply to matthies, 12-13-2004 19:53:00
LP may be a different story ,but if our 4020 gas started any better in cold weather I'd mearly have to look at the key instead of turning it.
Mike M
12-13-2004 18:54:02
I didn't see any mention of a new condenser or plug wires ? Make sure you use plug wires with wire in them and not that carbon fiber. Is your choke closing all the way ?
mike brown
12-13-2004 19:06:59
 Re: 3020 gas won't start in reply to Mike M, 12-13-2004 18:54:02
Once it is running and warmed up does it run well?
If so, it sounds like a too lean mixture when cold. AT work I'm resposible for a number of o/board motors. The new four strokes are set really lean to meet emission standards and they start better with the throttle at or near idle. You may have tried that. Also with colder weather you may need to fatten your mixture a bit since the gas doesn't vaporize as well.
