Early styled A front rim part numbers?
Randy in San An
02-11-2004 08:44:25
I have a '39 (early styled, sn 47989x) A with missmatched front wheels. One of the wheels places the tire against the pedestal. I can't find numbers on either rim. JD Repair catalog 47-R (eff 4/15/40) shows JD 1232 R to be the correct rim. The illustration matches the rim on the tractor that seems to fit correctly. Looking at the rim, I don't think it is reversible. JD Parts catalog PC675 (3/1/60) says that JD 1268R is the correct rim but you can't tell anything from the illustration. It is listed as reversible. An out of town salvage yard has found me a 1268... His sources say that 1232 was an implement wheel. My gut tells me it is the wrong wheel. Can anyone tell me what is the correct wheel? Thanks for reading this far.
Dennis
02-11-2004 10:03:34
 Re: Early styled A front rim part numbers? in reply to Randy in San Antonio, 02-11-2004 08:44:25
Randy,
Correction to my previous post. I checked the rim that I have, and found that it has four slots and four sets of three rivets (not two rivets as Duane described). Maybe Duane can tell us what # my rim is.
Dennis
Duane Larson
02-11-2004 10:12:17
 Re: Re: Early styled A front rim part numbers? in reply to Dennis, 02-11-2004 10:03:34
Dennis,
If you make the measurements described in my earlier post, you can determine if it is reversible or not. But, assuming it is not it sounds like the JD1261R, as it was not stamped.
Dennis
02-11-2004 09:48:07
Randy,
From Duane's description, I believe I have a JD1238R rim that I would be willing to sell. If you want to post your e-mail address, I can send you a photo.
Dennis
02-11-2004 10:55:07
 Re: Re: Early styled A front rim part numbers? in reply to Dennis, 02-11-2004 09:48:07
Dennis: my email address is
[email protected]
Duane Larson
02-11-2004 09:33:28
Randy,
The JD1232R front wheel was used on styled A's until sometime in mid '41, when it was replaced by the JD1261R. The 1232 was slotted sometime in 1940. There are three versions of the 1232R - the first has no slots and 10 rivets attaching the wheel to the rim. The second has no slots and 4 pairs of 2 rivets, while the third has 4 slots and 4 pairs of 2 rivets. None of them are stamped with the part number (some replacement wheels made later were stamped, and welded rather than riveted). The 1232 wheel is non-reversible, and uses hub AA1399R, casting number A1553R. If the difference between the distances measured from the center of the wheel to the rim on both the inside and outside of the wheel is about 1", the wheel is non-reversible. If the distance is 2" or more, it is a reversible wheel. You can apply that test to your odd wheel, but it sounds like a reversible wheel. Most reversible wheels I have seen are stamped with the part number.
You probably want to find a JD1232R wheel with no slots to match your existing wheel. You might try Dave Cook (1-715-373-2092), Phil Miller (1-319-683-2763), or Marlin Smith (1-712-489-2570)
02-12-2004 08:51:07
 Re: Re: Early styled A front rim part numbers? in reply to Duane Larson, 02-11-2004 09:33:28
Duane: thanks for the detailed response to my front rim question. I really appreciate the information I am able to get from this forum.
