DLTX 7 or 17????
Paul Winter
12-13-2004 14:13:43
A friend of mine has brass carburetor looks to be marked 7. but there is mark in front of 7. I can find no reference to a # seven carb. was there ever a # 7? is this a #17 wich makes it a late gpwt carb. any ideas of worth?thanks Paul
Duane Larson
12-13-2004 14:33:17
 Re: DLTX 7 or 17???? in reply to Paul Winter, 12-13-2004 14:13:43
Paul,
The DLTX7 brass body/cast bowl is seen on the (correct) over-top steer GPWT. I'm not sure if a DLTX17 has been seen (I haven't). There was a pattern with Marvel Schebler DLTX carbs - they came out with brass bodies and cast bowl about 1933, with numbers like 5, 6, 7(?), 8, and 9. Then about 1936 they went to cast iron bodies and bowls, and added 10 to each of the previous numbers. The DLTX5 became the DLTX15 (late GPs), DLTX6 became DLTX16 (D), DLTX8 became DLTX18 (A) and DLTX9 became DLTX19 (AR/AO). So, that would suggest a DLTX17 would have a cast iron body.
If the "7" is clear and the number preceding it is not, the first number may be something other than a labeling mark? Or, perhaps someone will let us know they have a DLTX17.
FWIW -
