44 JD-A Backfires thru exhaust
Hill Billy Boy
12-13-2004 13:52:20
Recently inherited JDA 1944 Hand start while using just acted like it ran out of gas. Rebuilt Carb and now it is very hard to start after running 30 seconds or so backfires thru exhaust and quits. Will restart after awhile but does same. New to the JDS but seems like fun any help I can get will be appreciated.
Hill Billy Boy
12-21-2004 09:05:13
 Re: 44 JD-A Backfires thru exhaust in reply to Hill Billy Boy, 12-13-2004 13:52:20
Readjusted carb runs like a champ. Sounds like a JD again appreciate the help. Have several more JD's I am sure I will need help with, MERRY CHRISTMAS AND GOD BLESS ALL !!!
Lee B
12-14-2004 00:03:53
I'm thinking the key phrase here is 'acts like it ran out of gas', it did! And probably because it is isn't getting enough due to blocked or plugged screens starting inside the fuel tank, at the sediment bowl and finally at the carb inlet (3 screens). Verify solid and copious fuel flow at the carb by removing cap screw next to fuel line connection (carefully) at carb and turning on the fuel. The carb's fuel screen is under that inch and a half sized washer that the cap screw holds down.
If you get good flow there then you need to adjust or re-rebuild your carb. 30 second time you mentioned is a dead giveaway to restricted fuel flow though.
Welcome to the fold - they are fun.
johndeereman
12-13-2004 16:39:16
sounds like youve got a fuel delivery problem either the gas aint gettin to carb could be plugged line or the hole in bottom of tankis partially bloked or the carb is set to lean or another possibility is the carb is sucking air spray either around carb with tractor running see if it speeds up
