3 brush generator voltage regulator
Loon Yi
12-13-2004 08:46:56
Can I install a voltage regulator rather than a cutout relay and resistor type switch for low/high charge and lights on a 3 brush generator without damaging the generator? TIA
John T
12-13-2004 09:10:57
 Re: 3 brush generator voltage regulator in reply to Loon Yi, 12-13-2004 08:46:56
Loon, yes you can. While many of the older 3 brush Generators were used on the cutout relay and light switch type Field control systems, you can still use the more modern Voltage Regulator to control/regulate Field current PLUS disconnect the VR as the cutout relay did since the VR does BOTH functions. I suggest you move the Gens third brush as close as possible to the fixed brush (max charge setting) near it before installation. Then, of course, its the VR"s BAT terminal wired up to the Ammeters load (NOT to Battery) terminal (should be where old cutout relay was wired),,,,, ,ARM on VR to the Gens Armature post, FLD on VR to Gens Field post, polarize her and you should be good to go. Make sure the new VR is compatible with that Positive ground system, assuming youre still like that as original.
John T in Indiana
Ravgardner
12-13-2004 09:51:31
 Re: 3 brush generator voltage regulator in reply to John T, 12-13-2004 09:10:57
John T. I've been considering doing this to the 42 H I'm working on. I don't know how many brushes the generator has, but do you think it could be done. What will the correct police think?
John T
12-13-2004 11:16:44
 Re: 3 brush generator voltage regulator in reply to Ravgardner, 12-13-2004 09:51:31
Rav, sure it can be done as I posted above and makes for better overall regulation. As far as any "Correct Police" I figure its our tractors n sweat n money and we can do as we please unless authenticity is an issue and you want her original and make that choice. All you do is set any third brush (if it has one) at max charge and replace the cutout relay and light switch function (it can still remain in place and work the lights) with the proper voltage and ground Voltage Regulator.
John T
Ravgardner
12-13-2004 11:25:18
 Re: 3 brush generator voltage regulator in reply to John T, 12-13-2004 11:16:44
Thanks John T. I am not really concerned about the CP making comments. But Since buying the H, I have been puzzled why Mother Deere did not put a VR on this tractor. Were voltage regulators available and used on any 1942 JD's?
John T
12-13-2004 12:36:08
 Re: 3 brush generator voltage regulator in reply to Ravgardner, 12-13-2004 11:25:18
Rav, Specs n Data isnt my thing, as I have little of it, Duane Larsons the go to guy in that regard. I can answer questions and wire em from knowing how thigns work, but Im NO CORRECT POLICE (and dont wanan be lol). My SM 2029 Manual shows the Delco 1116816 Regulator used on ALL H tractors, but I have no idea what (VR or Relay) that number is??? Generally speaking, the 3 brush Generator and Cutout relay and light switch system was on the early and many 6 volt units, some A and B I believe and the M etc. Im not much of an H man, I cant even find any wiring diagrams, sorry.
John T
