Front Wheel Bearings
Dan 41 B
02-11-2004 07:41:40
I'm changing the front Wheel Bearings on my 41 B, Both the inner and outer bearing along with the inner cup and felt. My question is, does the inner cup come out by knocking it out with screwdriver from the front side? Or does it come out someother way! Also the felt pad that is by the inside cup, are there two of them as I only see one, I received two of them when I purchased the bearings and cup for replacement. Your comments are appreciated. Thanks in advance for your imput.
Dan 41 B
02-11-2004 11:39:59
 Re: Front Wheel Bearings in reply to Dan 41 B, 02-11-2004 07:41:40
Thanks for the info as I thought that might be the case and will try to get them in this evening and will advise the progress.
Clooney
02-11-2004 10:44:23
Dan, those bearing inner races knock out from the rear [inside].. If you dig all the old grease out you should find a couple of cut out spots in the hub that allows a long drift to get behind those races & drive them out from inside the hub..
~If you are actually talking about removing the felt retainer the easiest way to get that out is to pull the outer wheel bearing out, then put the spindle nut back on, then slide the wheel & hub out against the nut so the nut catches the inner wheel bearing.. That will usually pop the wheel bearing & felt retainer out..
~On the felt seals.. There are usually two required per wheel.. Two together are pretty thick so what I usually do is use one new felt & one old felt per side & that seems to work out about right..
[email protected]
Bguy
02-11-2004 10:16:54
Dan41B, Tap the retainer out thru the hub from the opposite side, I use an socket extention (yea, I know), a short piece of pipe or etc.. It usually doesn't take much. There are supposed to be two felt seals in each retainer. I have seen several where someone had only used one for some reason.
